IF it need EITHER at this time of the year then she is way past and over haul . As if they are wright then they will start below freezing with out either . Either in them engines is extremely hard on them and can and will break rings . The valves may have beat them selfs deep into the head and this will cause low compression and hard starting . The biggest down side of the D361 it is not and engine for the novice to try his hand at a rebuild .When i do one it is done out of chassie and it is line bored decked contour bores recut and the block is bored .010 off the center line of the crank due to core shift over the years. Then we do the head complete with new valve seats new valves and spring plus guides along with a light truing cut . Then the sleeves go in and with a press fit . Then each sleeve is lightly honed to remove any wrinkles and each piston is hand fitted to each hole . Then you do 6 hal mary's bow to buda at sun rise and hope and pray that you did it wright .
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
