Most Fuel level gauges use a resistor in the sending unit to send current to the meter. the meter then converts this to needle movement. (usually using a bimetal heat sensitive bar with a heater wire wrapped around it, or by an electro magnet movement sensitive to current. In most applications, the gauge gets power through a IVR (instrument Voltage Regulator) or directly from the ignition terminal on the key switch. From the gauge the current flows to the tank sending unit, and from the variable resistor in that to ground. It may not make a difference which post is connected! I hope this helps some. Jim
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
