Posted by karl f on June 17, 2010 at 12:57:55 from (209.188.106.159):
see post & replies http://www.ytmag.com/cgi-bin/viewit.cgi?bd=farmall&th=766857
I tried a 194 bulb. It helps the excitement, since it is now at 3/4 throttle instead of nothing at wide open. not measuring with tach but it is also the cough/kill spot when cold.
My goal is for 1/2 or less to guarantee charging in MN winter during warm up time before throttle can be pulled to higher rpm.
a 194 bulb measures 4 ohm. the sealed panel light i was using measures 30 ohm. Need to find a panel fixture that will fit a 5/8 or 1/2 in hole and take a 194 or a bayonet with 4 ohm or less resistance. tractor has sat a week without getting a dead battery, voltage in the 12.3-12.4 range, so that should indicate no diode leaks in the alternator.
i"m using stock size belt and smallest pulley (2.5in) I can without hood contact (1/4in clearance), which along with low rpm cut in are my goals for the conversion.
Looks like a regulator change or smaller belt with smaller pulley are the only way to get it any better. This alternator maybe even was a 1 wire but I never tested it as such. With the 2.5 pulley and 194 bulb the reman i tried previously might excite sooner as it was probably 500 rpm in my favor compared to the one on there now.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
