Posted by Jimb2 on June 12, 2010 at 19:11:01 from (72.38.123.67):
In Reply to: 585 loader hookup posted by MikeinKy on June 12, 2010 at 14:56:28:
Hi you can spend many $$ at CaseIH and by a power beyond plate for the end of the aux remote valves. IF you never use the hydraulic remote outlets then you can connect the IN side of the Joystick valve body to one remote outlet and connect the OUT to the other remote outlet and tie the remote outlet lever back so the remote outlet is open. If Joystick is working in wrong direction, just swap the hydraulic pipes at the remote outlets.
If you require use of the remote outlets at same time as loader then the cheap way to install Joystick control valves is: Removed the aux hydraulic return tube from the aux control valves to the draft control module under the seat. See tube at caseih.com parts for 585 hydraulics page 8-450 item 18 Tube assy Aux Valve return.
After you decide your method of connecting the Joystick valve then post again and I will supply more detailed instructions.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
