Re: H motor knock
Posted by Alvin Dick on June 06, 2010 at 20:47:06 from (70.100.17.131):
In Reply to: H motor knock posted by Chuck Tetherow on June 06, 2010 at 13:09:31:
I had an H with a knock and the crankshaft was bad. I could move the no. 4 connecting rod back and forth.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
