Posted by TX656 on June 05, 2010 at 09:01:13 from (69.34.243.195):
On a fresh overhaul (turned mains and rods) I have 43PSI at start up and 22-23 PSI HOT pulling disk. This is on a 95 degree day at 1400 RPM.
I have the blue ribbon manuals and can find no PSI specs in them.
Mechanic friend did the reassembly for me (after I jacked up the first the I split it) said the machine shop did a wonderful job and the clearances were now spot on per the blue ribbon manual.
Oil Pump has been overhauled and there is a new pressure relief spring and all new metal check valves in the oil filter housing.
I was expecting more like 80 PSI cold and 40 hot (nothing to base that on except some car engine overhauls.)
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
