I do not know which pump you have, so I will recommend two things. I would put a relief valve in it, on the pressure hose. I would probably purchase a set of valves with an adjustable pressure relief built in (set to 1200psi). I would not use the belly pump for a reservoir as it is below the level of the pump, and makes priming difficult. I would purchase (or fabricate) a reservoir of about 8qts. or so. The valving could be for either single acting or dual acting cylinders, with the return to the reservoir. I would continue to use the belly pump if it is operational, as it would give me more options. I would use hytran in the new system as well as the belly pump. Jim
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
