Posted by ScottyHOMEy on May 06, 2010 at 20:03:49 from (70.105.252.192):
In Reply to: stuck governor posted by rustytenn on May 06, 2010 at 18:48:22:
You're on the right track, rusty. The governor is basically an empty cavty that gets all the lube int needs if the motor is run regularly, but can get crusted up and sticky from lack of use.
The control side, between the lever at the seat up to the fly weights, can be worked loose with the lever, but the other side, that drives the carb, can still be sticky. Start with a good cleaning all over, with special attention to the bushings on the carb side, and replace any parts necessary in the process (like that pesky thrust bearing around the center shaft) and give it a try.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
