You're wanting quite a bit of extra power from that engine. To do that, you will need to get more fuel into the engine and you will need to get it burned efficiently. The "extra" parts will help you get there.
The 350 cam gives you a little higher lift and a little longer duration. The LP head has smaller combustion chambers for higher compression. There are tubes cast into the head called "runners" to take the air-fuel mixture to the valves and from there into the cylinder. Cleaning up those runners, and matching the manifold ends to the head ports gets you better air-fuel mixture flow.
With more air-fuel mixture under higher compression you could benefit from a hotter spark. That's how electronic ignition could help.
This project will not really be cheap, which is why a "worker" Farmall M might be a better choice for that generator. It came with the extra ten hp you want built in.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
