Posted by mkirsch on May 01, 2010 at 19:02:27 from (67.253.216.24):
In Reply to: cub mower slips posted by catfixer on May 01, 2010 at 18:10:17:
It's not a slip clutch. It's an overrunning clutch that lets the blades spin when you press the clutch. Without the clutch, the spinning blades would continue to push the Cub forward about 5-10 feet.
The overrunning clutch is shot. You can replace it or you can weld it solid, but be careful if you weld it because of what I said above. Make sure you pop the tractor out of gear each time you press the clutch pedal to prevent the problem.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
