Dean, you should have a round tube (about 2" in dia.) coming up the right side from the front of the fast hitch and hooked onto the torque tube, be carefull when you pull it off the pin as there might be some pressure on it, once it is off the pin you should be able to pull the lock pin out of the 2'' tube and extend the inside tube about 1 1/2 feet to the next hole, repin it then you hook that up to the touch control arm and then you can control the plow depth with the right hand lever of the touch control. Hope this helps. Chuck
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
