make sure there isnt a valve stuck in open position that may be struck by upper movement of piston if it breaks free. previous post recommended removing the cylinder head prior to any attempt to rotate crankshaft, i to strongly recommend that. a bent pushrod or broken valve are easy to prevent. what ever you do dont force the engine to try and rotate by pulling it to try to get it to break free(bent rod). soaking with 50/50 acetone and atf works for me. good luck, d.coleman
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
