Posted by Gary Hutchinson on April 08, 2010 at 10:23:52 from (192.236.23.13):
Hey all. Had a slow fluid leak from a fitting on an add-on hydraulic valve mounted to my F560 that is plumbed to the fast hitch. I removed a couple hoses to get clearance to spin the leaking elbow out (so loose I could remove without a wrench). I cleaned it and used some pipe dope on the threads. When I screwed it back in, it was starting to snug up but not tight enough in the rotation I need to run the hoses correctly so I had to go around again and it was pretty tight when I got to the proper rotation. I hooked the hoses back up and fired the rig up. Raising the hitch is normal. Lowering the hitch is slow and labored as if fighting against a load. If I shove the lever all the way forward (down) there is a detent for a "float" function. The hitch actually raises slightly. I'm thinking that screwing in the fitting tight damaged the valve (probably Chinese) and the check valve on the piston side of the clyinder is binding and not letting it empty out properly when filling the ram side. Sound possible? Other ideas?
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
