It sounds like you're plowing "virgin" sod. That's the worst or so I've been told.
Don't be afraid to go at the surface of the moldboard and share with an angle grinder and 40 grit flap disk, then 80, then a 120 grit random orbit sander. Change papers often when you get to the sander. Get it shined up as much as possible before you go plowing.
If you really want to get crazy, you can keep using finer and finer grits until you get to a mirror finish.
When you're done plowing cover the shined surface with a healty coating of grease gun grease (moly or lithium, comes in a tube). It'll be just as shiny come next spring when you go to plow again.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
