pick up a twin spool valve, and one with a float option is even nicer. take one hydraulic line from either front port of the belly pump, run it to the "in" on the spool valve. the "out" or retun line can be run either to the fill pipe or, i prefer a pipe tee on the bely pump drain plug, and use a pipe plug in the tee to allow for a drain plug. leaving the belly pump in the full on position will not hurt the pump.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
