Posted by rustred on March 18, 2010 at 16:50:57 from (74.198.148.43):
In Reply to: INT, UTILITY I.D. posted by black on March 18, 2010 at 11:41:31:
it would have to be a farmall as the utility has 28" rear rubber. but whats with the INT.stamp? maybe you meant 28" instead of 38" tires?then everything would make sense.if you posted the serial # thats the easiest way to tell.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
