The counter shaft is connected (even when the transmission is in neuttral)to the engine unless the clutch is depressed. So to turn the shaft, you have to tie the clutch down so it is disengaged. If you disengaged the clutch and could not turn the shaft, put the PTO in gear and then put something on the PTO to rotate the shaft. I use part of an old PTO universal joint with splines that fit on the PTO.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
