Re: Super H backfiring
Posted by farmallsuperc on February 27, 2010 at 15:55:04 from (69.207.67.79):
In Reply to: Super H backfiring posted by nk7 on February 27, 2010 at 15:44:51:
its possible it could be because of the mag instead of coil. it could also be something with the Governor or some wiring
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
