Does it smooth out under load? It is a common ailment for F20s to want to buck and gallop at idle. I blame it on the spark jumping around on an uneven rotor disc. You want to take the disc out and sand it smooth. The brass contact plate is pretty thick and you can remove a lot of material. The fiber disc itself will have a ring worn in it from the brushes and you need that ring to disapear.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
