per my dad, he would have been 88 this year, to make a regular or f 20 idle right you have to set the plugs at about .030 not what the book calls for. this is partly due to better fuel we have now. at the time these were built gas was about 70 octane, also these engines burned distalate or kerosene and were very low compression. doesn't cost much to try this might solve your problem. post back if it does so we can all learn. leroy
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
