Posted by D Slater on February 22, 2010 at 06:27:21 from (72.65.146.142):
In Reply to: Re: 450 LP head again posted by Blackland Dan on February 21, 2010 at 15:28:51:
Dan they did use the manifold you have on the 450 now on SM LP tractors below serial # 25931 under part # 357049 R91. That part # was just a 8035 DD manifold with a tee fitting already installed. Above that serial # they changed to manifold 358308 R1 or R11 with tee, the same manifold that would be original to a 450. If you run across a used 358308 check for cracks. Common place is toward engine below the outlet pipe. Reason IH give for the manifold type change was for more satisfactory performance in high temperatures.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
