Posted by sflem849 on February 22, 2010 at 04:07:54 from (69.197.84.192):
In Reply to: 450 LP head again posted by glennster on February 21, 2010 at 10:37:40:
randy hall said: (quoted from post at 20:28:50 02/21/10) what makes you think that the propane vapor mixture would be more explosive than the gasoline air mixture.
It has a greater Stoichiometric ratio and a lower ignition point.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
