Posted by sflem849 on February 21, 2010 at 18:51:53 from (69.197.84.192):
In Reply to: 450 LP head again posted by gary sedlacek on February 21, 2010 at 10:37:40:
Blackland Dan said: (quoted from post at 16:28:51 02/21/10) Thanks, guys. I'm thinking that predetonation wasn't a real problem because the previous owner ran it like this for the last 20 years. I think Wardner's statement about being cost effective is my deciding factor. I'll just stick with what I have.
Does anyone know what the compression ratio is?
Thanks again. Dan
Something scares me about running propand through a red hot manifold. What did the PO use the tractor for? Not many are used for plowing hard like they used to. Not too many other uses out there to work them long and hard like that.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
