Posted by randy hall on February 21, 2010 at 15:30:01 from (209.143.30.98):
In Reply to: 450 LP head again posted by Blackland Dan on February 21, 2010 at 10:37:40:
as taken from the blue ribbon serviceman's handbook a gasoline 450 has 138 lbs. compression at cranking speed, a distillate engine 89 lbs., c-281 with firecrater pistons 135lbs. and your 450 lp has 186 lbs. compression. every series ih improved the manifolds. m, super m, 400, and 450 all used different manifolds on the gas tractors.horse power at rated speed on the pto is 52.1 for the gas and propane models, 37.4 for the distillate and 47.4 for the diesel model 450.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
