With out a TA you still have seals inside and taking the top cover off you would be able to see where it is leaking from. As for hydraulic staying on high pressure, check your aux valve double to single action setting to be sure pins or not broke or bent allowing valve rotate too far, if that is ok, you most likely have a plugged orfice screen in regulator valve assembly.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
