The Occupational Safety General Regulations (Part 7) require that all tractors manufactured on or after January 1, 1974 be equipped with a rollover protective structure (ROPS) that meets minimum CSA standards. Tractors manufactured before January 1, 1974 should, where reasonably practicable, be equipped with a ROPS that meets requirements set out in Regulations for older tractors.
63 (1) An employer shall ensure that, where reasonably practicable, powered mobile equipment and industrial lift trucks manufactured on or after January 1, 1974, are equipped with rollover protective structures that meet the minimum safety requirements of the following standards:
(a) CSA standard B352.0-95, "Rollover Protective Structures (ROPS) for Agricultural, Construction, Earthmoving, Forestry, Industrial and Mining Machines - Part 1: General Requirements", or is certified by an engineer or the manufacturer to provide equivalent or better protection;
(b) where applicable, CSA standard B352.1-95 (R1999), "Rollover Protective Structures (ROPS) for Agricultural, Construction, Earthmoving, Forestry, Industrial, and Mining Machines - Part 2: Testing Requirements for ROPS on Agricultural Tractors", or is certified by an engineer or the manufacturer to provide equivalent or better protection; and
(c) where applicable, CSA standard B352.2-95 (R1999), "Rollover Protective Structures (ROPS) for Agricultural, Construction, Earthmoving, Forestry, Industrial, and Mining Machines - Part 3: Testing Requirements for ROPS on Construction, Earthmoving, Forestry, Industrial, and Mining Machines", or is certified by an engineer or the manufacturer to provide equivalent or better protection.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
