Posted by d. coleman on January 26, 2010 at 21:00:18 from (208.97.38.55):
just got a 53 cub and plan to rebuild engine if i can"t get it running with a tune up. i suspect low compression. i have used All State Ag Parts for a jd M and was wondering if any one has any suggestions on a o/h kit sorce. don"t plan to put tractor to heavy work, but want a kit that isnt "chines junk" also cant afford IH part prices. any suggestions or comments will be of great help. thanks, d. coleman(48jd M,51jd B, 49ac C, 53 CUB)
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
