Posted by The tractor vet on December 31, 2009 at 19:08:09 from (99.167.217.134):
In Reply to: points posted by Shawn in PA on December 31, 2009 at 17:46:35:
Well don't know why your having problems like that as we put a bunch of hours on the 706 each year and i do tune it once a year just to keep it at it's best. On my S/MTA about once every blue moon or when i think about it and it starts just fine . Now you said that it has been changed to 12 volts and that you have a 12 volt coil on it , well as for myself i NEVER use a 12 volt coil i just add a resistor to the STOCK coil and it works fine . Even the stock 12 volt farmall's use a 6 volt coil with a resistor and for a hotter start shot they use a wire off the starter to shoot a straight 12 to the coil on start up that bypasses the resistor from the starter. . Now you may have the coil wired backwards and this will give ya fits so make sure that the coil matches the grounding of the battery .
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
