Posted by ScottyHOMEy on December 19, 2009 at 19:13:13 from (71.241.215.22):
In Reply to: Re: H starter ring gear posted by redihplower640 on December 19, 2009 at 18:44:06:
No. The 180* advice is off. The quarter-turn, 90* is more to the point. A motor will come to rest when fuel/power is cut off and it will kind of settle when the last compression stroke not being driven by a combustion stroke on another piston wil provide enough resistance to stop everything. That is what tends to leave the ring gear resting in one of four general (not exact) positions that will take the most wear when the starter is next engaged. Soa a 180* turns won't gain you as much as a 90* turn.
But if you're going to heat it up to turn it 90*, you might as well take it off and turn it over. Depending on how bad it was chewed up on the original surface, it may take some dressing with a file or grinder so that the new side presesnts itself as square, but that's about it.
The faces on the ring gear are square. The bevel on the starter pinion are designed to synch and make the mesh.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
