H's start good when cold, if it turns over good, winter grade gasoline, and engine oil like 10 w or 5w30 and engine in good tune and reasonably good shape. If you have a 6 volt battery in the original size battery box it can be difficult to find a battery that size with really good cranking cold cranking power and or ampere hour ratings. Like others have said, good heavy cables, starter in good shape, I will add on starter to make sure it has a center bearing as some did not and under heavy cold starting torque situations it can cause armature drag. And it does help some to turn on the lights for a little while to help surface of plates on battery to warm a bit. Slow charge for a while before trying works good also. Many variables. During cranking the voltage will drop to about 5 volts or less so coil will naturally produce a weaker spark than at normal operating voltage of about 7.2 volts. Low voltage causes less current to flow through the primary winding in coil there for producing a weaker magnetic field in the secondary coil winding and you end up with a weaker spark .
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea
... [Read Article]
Latest Ad:
[More Ads]
