My H will start when it is around zero, but it is more willing if the battery gets warmed up with a charger for half an hour.
I think the real problem is that the gas is not evaporating when it is cold. Sticking a heater magnet on the intake manifold helps when it is really below zero.
I'm adding a second 6V battery in parallel to get more cranks out of it when it is cold. Choking the tractor for 2 cranks is plenty at 30F. At 0-10F it needs 4 or 5 cranks before it will fire.
It sounds like we will be sending you some more chilly air early next week...
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
