Posted by Jon Young on November 29, 2009 at 06:54:59 from (70.217.62.245):
In Reply to: Re: Need Wiring Help posted by Janicholson on November 28, 2009 at 13:27:02:
This has the original starter/generator. Been checking one wire at a time. When I try to attach the red wire to the BAT.terminal on the voltage regulator, it arces. Have tried two other regulators(same thing happens). Could the generator have a enternal short? Every thing else is new.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
