Posted by billde on November 26, 2009 at 04:25:48 from (72.26.89.156):
In Reply to: Farmall Cub Oil ? posted by Lou1969 on November 25, 2009 at 13:31:14:
Pull the pan and tappet cover, clean everything up, use Rotella 15w 40. The detergent will SLOWLY clean the engine and the zinc in Rotella is good for the flat tappets. Leave the snake oils on the shelf, change oil when it starts to darken.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
