I still cant say if you have a late Ford type solenoid or one like Janicholson mentioned????????
If its the late type AND IT WORKS and is grounded, when you apply 12 votls to the small S terminal THE OTHER LITTLE I TERMINAL IS SUPPOSED TO THEN GET HOT !!!!!!!!!!!!!! Its lil I terminal is (supposed to be) hot ONLY when the solenoid is energized with 12 volts on its S terminal...
A test lamp and multimeter is all you need to check out that solenoid, its NOT rocket science. if its NOT the late Ford type but needs a ground ALL BETS ARE OFF and if I know that then I will guide you different or just do as Jim already told you
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
