I will have to check the butterfly to see the movement. I put oil in the pump with the side cover off thats all. I have ran it with the side cover off of the injector pump and it don't have any fuel dripping from the pump. even after quite a wile of running at high idle and more. No new nozzles yet. That will most likely be my next step. Mostly concerned with the over fueling issue right now. Thinking the injectors may be stuck in full open possition. Will try and get to this list this weekend. Thank you JF
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
