The oil in the bull gears (final drive) is separate from the oil in the rear frame unless someone has updated the housings to the later style. The change was to drill holes in the rear frame so that the oil could run between the rear frame and the axle housings. If it is updated the check/fill plug on the axle housing should have been cut off so that it can not be removed to indicate the change was made on that side. Some tractors out there have only one side done.
If you lost the steering and the tractor will not move out of the field you most likely have more problems than changing the oil is going to cure. What other symptoms do you have? Was there a change in noise? Do the rear hydraulics work? Does the PTO work?
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
