Posted by Janicholson on October 09, 2009 at 14:56:46 from (64.61.211.175):
In Reply to: My IH 544 won't run now. posted by Eric Kaltenbach on October 09, 2009 at 09:15:28:
Clean and set the points. Make sure there is ignition voltage going to the coil with the ignition on (not the start position) There may be a bypass that allows the ignition to get voltage when cranking (from the starter relay, that little can on the starter). It is connected to an "I" terminal, on the relay (if there are only three terminals on the relay, ignore this possibility), and to the coil side of the ballast resistor on the coil end. This will provide that "starts when cranking then quits when turned to run" symptom. A bad ignition switch or ignition wire will cause the actual problem. JimN
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
