I'm sure this has been discussed many times and although this F-20 was bought new with electric starter and lights it was not "factory". There are many many many documents that prove otherwise. Although there were many available setups that dealers could install.
The only F series tractor that ever came with factory start was the F-14.
I'm not at all trying to sound rude but am more or less just wanting you to be educated in what you own. If you believe otherwise just do a little research online or search through some books on the F-series tractors and you'll find the truth.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
