It could also be valve adjustment, but Jeff has a good idea for the first and easy thing to check out.
The other common places for air leaks are at each end of the manifold -- where it joins up to the head and where the carb mounts on the bottom. Those can usually be fixed by either tightening up anything that's loose or replacing a deteriorated gasket. Worst case is a rusted-through manifold, which can sometimes be repaired but often is easier to just replace.
The easiest way to test for leaks of this type is to get your tractor started however you have to, and let it idle. Before it gets too hot, take your starter fluid and spray around the places where it might be leaking. If it picks up speed any, you've located a leak.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
