Posted by D Slater on September 27, 2009 at 20:30:23 from (72.65.129.239):
In Reply to: M engine swap posted by 41106 on September 27, 2009 at 17:59:24:
Unless you have a late M with a 12 inch clutch or a late belley pump housing to clear the 12 inch clutch. Use the M flywheel and clutch. If you could use the 400 size flywheel and clutch the clutch plate needs changed to a SM type. Switch throttle arm and shaft on governor. Run vent line in top of valve cover to air cleaner intake pipe vent line opening. Depending on what model M it is and if a live hydraulic pump is used or not a ignition drive housing and shaft from a SM or late M may be needed to match the 400 front cover bolt pattern. If using a 400 carburetor the choke lever will be toward engine instead of out like a M. So choke rod will need a little work. Sometimes the 2 head studs where the M throttle bracket mounts are not long enough on a 400,450 to have full threads on the nut after bracket is added. Stock ignition unit for a M may have to much advance for a 400,450.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
