Are the wheel bearing tight or loose. Should be snug. Are the rims bent? Jack the front up and spin the wheels. Watch the gap between the tire and the ground. Loosen the bolts and adjust until the rim on the wheel is centered. The rest of the slop is in the joints of the steering shaft and the worm gear in the bolster. Some of the steering gears can be flipped around to put teeth with less wear in contact with the worm gear. You may be able to tighten the bearing on the end of the worm gear. Which will help alot. SDE
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
