Re: Got the belt pulley inards out. Bearing question...
Posted by J.J. from Afton on September 23, 2009 at 23:27:38 from (24.118.175.64):
In Reply to: Got the belt pulley inards out. Bearing question... posted by Mike CA on September 23, 2009 at 23:14:10:
You can tell the bearings are bad if you see any chipped or broken balls or rollers. Also if there is any rust or corrsionin the races or on the balls/rollers themselves it should be replaced. Another way to tell is if there is any resistance or friction when you spin the bearings in your hand than theres either damage or foriegn matter in the bearing. If the spin smoothly and freely they are good to go.
Sorry for long answer but hope this helps you.
-Jordan
Today's Featured Article - Restoring a John Deere 2010 Diesel Tractor - by Jim Nielsen. Following seven years working in California's Silicon Valley, my wife, baby son and I moved back to Australia to retire. We bought a small 'farm' of about 50 acres near Bendigo, in the state of Victoria. I soon found that it would be very useful to have a tractor around the place for things such as grading our long drive and brush-hogging the fields. I was also embarking on planting 1000 eucalyptus trees, and hence I would need a ripper, small disk plow, sprayer etc. to get these things accompli ... [Read Article]
Latest Ad: 1945 Farmall wide body gas with pto and front plow. Runs good but needs new points. [More Ads]
