You can use silicone but only use a small amount, snug bolts but do not tighten, leave sit for at least 12 hrs, preferably 24hrs, & then tighten. If you use too much silicone or tighten before allowing it to settup you can "blow" the gasket out as the stuff is slippery.
My personal preference is Permatex No. 2 or aluminum paint.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
