Probaly not really needed but a thin coat on both sides of gasket will not hurt anything. I recently put thermostat in small block Chevrolet and had leak, took back apart and recleaned and inspected (everything looked good) put back together still leaked. Coated third gasket with silocone and no leak.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
