Using the GPM or cu-in/rev rating of the hydraulic pump and the bore and stroke of the cylinder one can come up with a very educated guess about the cycle time.
In other words, the pump only positively displaces so much fluid per revolution of the input shaft. The hydraulic cylinder has a known volume in cubic inches that need to be filled to make a full stroke. How fast the hydraulic pump shaft is running makes a difference.
The pump peak pressure and the cylinder bore are used to determine peak force that the hyd cylinder can generate.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
