KC Bob said: (quoted from post at 16:42:39 09/03/09) Can you run a log splitter off of the M
Standard M hydraulics are single action... You would need to plumb it to an auxillary valve and wire the lever back on the tractor. If you tried to operate it directly from the tractor valve, the cylinder would stroke one time and not return. Loader, disc or plow will drop from their own weight.
Also depends on the diameter of the splitter cylinder whether or not it has enough force to split a log.
This post was edited by IH fan at 16:07:09 09/03/09.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
