I have welded nuts on to broken bolts. Sometimes the heat from the welding will break the broken bolt loose for you and they will turn out easily.
Or try to drill them out. Measure how deep the hole is in the jacket and make sure that you do not drill through it. Sometimes I will use a 1/4 by 20 tap to thread a bolt in to a broken 5/16 bolt. Apply heat to it after you have drilled it out. Maybe the thin wall of the broken bolt will absorb enough heat to come loose. Use a penetrating oil after you have heated it and hope it sucks in some. Just be careful to keep the drill centered on the broken bolt the best that you can. Steve
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
