if you can run a loader from the stock hydraulics why cant you run a wood splitter,its just a hydraulic cylinder,,I am able to use my stock hydraulics to run a loader and also to raise/lower my haybine,disk and other hydraulic stuff,so why wont it run a splitter?all I have is quick couplers coming off the side of the tractor where the pump is,works fine,, better not tell my M that it cant do it huh.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
