I've got a '50 H in original condition. It has the ignition switch mounted in the same bracket that is used to mount the belt pulley lever and the radiator shutter control. I don't think the ignition switch in the amp box was done until the Super H was introduced.
For what it's worth, my 1940 H has the ignition switch in the same approximate location as the '50.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
