This valve on the cylinder seems to work like it should. It kicks the lever/valve into neutral automatically but the tractor is still under load in the neutral position. Push the lever forwards into float and the load is no longer there as long as the lever stays in the float position. Going to switch to the other set of hyd. outlets and see if they do anything different. Thanks, Dan
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
